Réduction des coûts
Réduction des coûts
Messagede noux » Mer 22 Fév 2006 15:22
Est-ce que ça doit forcément passer par la standardisation comme semble le penser la FIA ?
Not everyone is happy with the idea of a standard Electronic Control Unit (ECU) but it's one of the FIA's proposals for 2008 and the sport's governing body intends to pursue the idea. The FIA is "seeking expressions of interest" from potential suppliers of the system, with the purpose of supplying all the teams from 2008.
An FIA press release stated that the system will be required to control the following:
*An 8 cylinder engine, including single injector and spark plug per cylinder, one throttle actuator, pneumatic valve air pressure, two lambda sensors and two fuel pumps.
*A 6 or 7 speed semi-automatic sequential gearbox and hydraulic multi-plate carbon clutch.
*A hydraulic differential
*An energy recovery system
*A number of digital output drivers
The supplied system will be required to include:
*Steering wheel electronics for switch inputs and driver displays.
*Data acquisition and logging capability sufficient for all control, diagnostic and chassis performance analysis functions with fast data upload capability
*An accident data recorder
*A nominal 12V regulated car system voltage supply
*A list of approved sensor and actuator types
*A single infrastructure telemetry system
The ECU is intended to replace expensive electronic systems such as traction and launch control in order to reduce costs. Driver aids have been banned but then reintroduced over the years as policing of the bans was not guaranteed to be effective.
The standard ECU should prevent any illegality and also would be welcomed by those who think driver skills are more important than technology. However, there's also the faction that believe standard systems undermine the sport's reputation for technological innovation.
Messagede HAD RF1 » Mer 22 Fév 2006 15:28
Mouai c'est n'importe quoi tout ça, la F1 n'est pas du GP2 !
Messagede FFRF1 » Mer 22 Fév 2006 15:48
Bah oui, c'est du n'importe quoi ......
Encore plus quand on parle d'un moteur pour 3 WE ...
Messagede Drool1 » Mer 22 Fév 2006 17:28
Tiens justement coté viry, en interne on en pense quoi de ces regles, electronique commune, limitation du regime, moteurs 3 week end...
Ca doit vous enlever des "defis" quand meme, etre moins interessant non? meme si il y a toujours du boulot a faire sur un moteur mais si les plans sont figés comme le veux la FIA :b005
Messagede Dazul » Mer 22 Fév 2006 20:27
Si la F1 est standardiser, y a auceun interet en tant que constructeur à y rester.
Messagede FFRF1 » Jeu 23 Fév 2006 07:12
Drool1 a écrit:Tiens justement coté viry, en interne on en pense quoi de ces regles, electronique commune, limitation du regime, moteurs 3 week end...
En résumé, plus ça va, moins je suis le seul à dire "autant faire du GP2" !!!!
Tout le monde est conscient qu'il faille réduire les coûts mais les propositions faites ne vont pas forcément dans le bon sens.
A noter que le RS26 coûte, pour l'instant, moins cher d'environ 15% que le RS25. Pourquoi ? Bin tout simplement en rationnalisant les études, en allant à l'essentiel, etc.
